Re: Kitchs 1200 Coupe - now with brakes!
Looking so sweet Kitch. That pipe work looks fantastic.
Kitch
Post by Kitch »
They ain't perfect, got a few wee rough bits.
was a tedious job to form them all up from the coiled tube,
wouldn't want to do it again in a hurry!
Kitch wrote:They ain't perfect, got a few wee rough bits.
Yeah but new hard lines look so good
2 doors
Post by 2 doors »
very nice, well worth the effort id say.
before you give it the final bleed, you're really gonna need to fit your brake hard line grommets where your lines protrude through the inner guards.
Kitch
Post by Kitch »
I am buying blanks Bart, and going to punch them, and split cut/glue around the tube to suit.
as you may pick up the hard lines are quite a bit off centre.
have not managed to find new after market 30mm grommets as yet, but may try 'basis' resto parts
Try Scott for genuine ones?
joelbrown
aka: Joel
Post by joelbrown »
Where did you get those sway bar to lca rods? They look pretty trick
1990 1200 ute
Kitch
Post by Kitch »
They are a bit of a throw together Joel; M8x90 cap screws, with nolethanes bushes and original cup washers, the gold colour spacers, are actually some tapered spherical housing alignment bushes I had lying around from either my camber plates or my panhard rod ends. they seem to look ok, they have some fuel hose internally to adapt the difference in internal diameters. hope the setup does the trick
Kitch
Post by Kitch »
Not much of an update, but spent a couple of hours in garage tonight, so thought would throw some pic's up.
I have assembled all the steering box & steering arms etc, still need to be tightened and greased, but its all in the right place.
I needed to get it rolling, as need axle stands to put under another car, I could not put the 12" wheels on the front, as have the S13 brakes now fitted up, so I tried on my new 14x6.5" Formula one's (mini lites) that I acquired a couple of months back, which
fitted very nicely.
Plan to get the motor (short block) & box installed in next couple of weeks, and start fitting things off, and also start some work in the cabin. also need to sort out my fuel feed system / surge tank setup....
Good to see it down on the floor again.
