I'm pretty sure with some more imagination and tweaking i can make this work
I'm pretty sure i can make it work, if not i can still have unequal length's and still have some pretty sweet headers.
Ah I should have worded my post properly, I am after 12mm Ring Gear Bolts. I too tapped out my rear cover to M10 and have done a few for other people too.sr1600 wrote:Are you arfter the standard r200 bolts, i tapped all mine out to m10x1.25 for the newschool rear cover so they are redundant now.
Best thing is with the new skool cover on there it fits between the boot crossmember that is notched normally in the 1600..........win
