I purchased these from Japan for use on my Sunny truck but have since gone to FCR carbs.
What you get:
AE101 20V 4AGE throttle bodies
Factory linkages and throttle cam
Custom polished alloy SR20 manifold which has built in water outlets
New fittings for each inlet tube
Polished inlet trumpets
If more images are needed I can supply at request.
Contact me here by sending a message or contact me on 021 157 1036, please no window shoppers
I’m after NZ$650 for the above and I am happy to post internationally for those with a strong FX rate.
See http://www.beeoneoneoh.com" onclick="window.open(this.href);return false; for more of my Sunny truck and the same images but slightly larger.
FS: SR20 ITBs + mani etc - Auckland
Re: FS: SR20 ITBs + mani etc - Auckland
DO NOT TEXT ME ASKING WHAT IS REQUIRED TO RUN ITBS ON YOUR SR20. PLEASE RESEARCH BEFORE YOU WASTE MY TIME
Doesn't seem like much of a deterrent. In fact I may just txt to see if you docheater_5 wrote:
If one more person texts me in broken thug text speak asking what is needed to fit these to whatever you've swapped an SR into, I'm going to break my phone.
Here's a similar set up on a VE head, although not exactly the same. You get the idea.
I just filled my pants.
SR would look too small in my car however.
- hsepwr
- aka: Craig
If you want to sell these you have to expect people to ask questions and to waste a bit of your time as to weather they will fit/work etc, not everyone will understand how these work or if they will work so if your actually wanting to sell them back the truck up. I deal with people asking stupid questions all day as to weather this carb will fit that manifold or will that dizzy fit this motor and if i gave the same response you give my doors would be shut in under two weeks so chill out help people and you might actually sell them otherwise good luck.cheater_5 wrote:DO NOT TEXT ME ASKING WHAT IS REQUIRED TO RUN ITBS ON YOUR SR20. PLEASE RESEARCH BEFORE YOU WASTE MY TIME
aww hey ow hw hrd dese b 2 fit 2 a L20B cuz? itz nt a SR so figas u wud hlp me che cuz HIT IT NIGGA YEAH BOI ARANUI REPREZENTcheater_5 wrote:DO NOT TEXT ME ASKING WHAT IS REQUIRED TO RUN ITBS ON YOUR SR20. PLEASE RESEARCH BEFORE YOU WASTE MY TIME
