anyone fitted a fwd sr engine as rwd layout?
all your DIY needs
Evil13
aka: kane
Post by Evil13 »
looking at doing some work on the datto soon if i can use the engine without swapping to a rwd block it will save alot of time and money anyone done it?
1200 sedan
1961 ford galaxie
nick_m
Datsun Master
aka: Nick m
Re: anyone fitted a fwd sr engine as rwd layout?
Post by nick_m »
I did, I shut and cut a altezza 6 speed behind an sr20ve. I cut up the sr bell housing too and moved the starter motor bulge higher to match the higher starter motor position on the fwd block and re drilled holes to match. Swap the RWD sump onto the fwd block then all the passenger side bolt holes line up as well as all the holes along the bottom, which leaves the 2 starter motor bolt holes to be repositioned and the top bolt on the Drivers side.
Mine looks pretty frankenstein but it works and all holes bolt up.
Peolple Do bolt the FWD blocks up as per what I said but just grind but the bellhousing material that fowls with the starter motor and then just drill the holes that dont line up and add crush tubes. Less work than moving the starter, however the little buldge on the bell housing for the starter obviously wont line up if you do it the latter way.
Also there is no passenger size engine mount bracker holes as but there is holes you can pick up on to fabricate a mount. The Drivers side one bolts up as per normal
Evil13
aka: kane
Post by Evil13 »
Thanks for the info ill dummy up gearbox next few weeks and see how it looks
1200 sedan
1961 ford galaxie
unlimitedpower
Datsun Mad
Post by unlimitedpower »
I'll agree anything can be done and i love to see things done differently but unless you are doing this to a VE engine. (ive played alot with these) then i would use a RWD engine i know FWD motors are cheaper but not after the time and effort you would need to put into it.
Even then if you are going to use a VE engine use a RWD SR20DET block (has oil squirters which you don't really need so just use a DE block for a 5th of the price) and swap every thing over into it from the VE engine and run and external oil feed. All other problems you have like dizzy position hitting fire wall and manifold etc will still be there but you would encounter these anyway.
Just my opinion unless your good at fabrication then id prob put a bit more research in first.
Evil13
aka: kane
Post by Evil13 »
Yea it's a sr16ve.
I've already built a rwd sr20vet for my silvia and was planing on using my spare engine for Datsun but I'd rather have it for a spare and if I blow the 16ve I won't have to build another engine I can just bolt a new one in
1200 sedan
1961 ford galaxie
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
reason i went that way too. Being a race I can buy a $800 20ve to get going again if i need to
Godzilladat
Datsun Nutter
Post by Godzilladat »
Got any pics of those Mods Nick? Interested in the gearbox mod.
Evil13
aka: kane
Post by Evil13 »
I'd be keen for photos. Could you tell me on the fuel rail what is supply and what is return
1200 sedan
1961 ford galaxie
unlimitedpower
Datsun Mad
The return will be right next to the fuel pressure regulator,
I do see the point of being able to quickly pick up a new complete VE engine and drop it in. They are really good engines out of the box.
Just putting the finishing touches to my VE head swap on my Autech P11 Primera 4WD wagon.
Evil13
aka: kane
Post by Evil13 »
unlimitedpower wrote:The return will be right next to the fuel pressure regulator,
Theirs a regulator on both lines apparently ones a suppressor but they look identical
1200 sedan
1961 ford galaxie
