L series flywheels
- Evil13
- aka: kane
L series flywheels
Wondering if theirs a difference between ld28 l20et etc...
1200 sedan
1961 ford galaxie
1961 ford galaxie
Re: L series flywheels
Yes, LD28 flywheels are very heavy and have timing marks (for the injector pump?) on them.
Pretty much all the other L6 ones are the same, 225mm clutch is common, 240mm is rare.
They should do, if you stay within the 225mm range. I'm not 100% sure on the LD ones, the flywheel was massive but I think it was the same height as an L20 one.
