Datsun 910 Project, EFI conversion advice?
Bluebird910
Post by Bluebird910 »
I have a Datsun 910 that I'm working on, it has the L20B engine. The carburetor has been causing issues, so it's a good excuse to convert to EFI.
I was thinking that I could get a second-hand manifold from a more recent nissan, but I'm not sure what would fit. SR20? maybe a CA18? I have no idea.
Any advice?
Picture related
broke
Datsun Addict
aka: John
Re: Datsun 910 Project, EFI conversion advice?
Post by broke »
L18E has a manifold that will fit, I think datsunboy is using one with a CA18 computer and Nistune. Or you could buy those sweet throttle bodies that go onto Weber style manifolds if you have lots of $$$
Lang2
Post by Lang2 »
L18e manifolds wont fit l20b unless you drill new manifold studs and drill slots in the inlet ports for injectors,
IMO a good set of twin su carbs are a great upgrade without going all out, start and run awsome and are reasonably cheep, i know it's not injection but its an option
Bluebird910
http://www.trademe.co.nz/motors/car-par ... 656095.htm" onclick="window.open(this.href);return false;
Would something like this work?
brocky41
aka: Brocky
Post by brocky41 »
Hi - you could always try an LD20 diesel manifold - see pic below - mine splits at the u turn so you could run a custom plenum on top or use the whole thing with a throttle body mounted to the front.
heaps of room for injector bosses and fuel rail etc - it may not bolt straight up to head but would be very close - they came out in some diesel vanettes largos and serenas etc aswell
This ones in my r30 wagon
Uploaded with ImageShack.us
Lang2
Post by Lang2 »
Bluebird910 wrote:http://www.trademe.co.nz/motors/car-par ... 656095.htm
Should, just needs an air cleaner for it
