I,m needing two wheel nuts like the ones on the Rt, they are a flat face and use a washer/ spacer. I'm missing all of the washes apart one so I need 15 spacers/ washers.
The size of the washer is 27mm OD, the size of the hole is about 22.5mm and its 4mm thick.
Any help, thanks in advance.
Wheel nuts and spacers/ washers
- aka: Jas
- aka: Jas
Re: Wheel nuts and spacers/ washers
I,ve found some washers on Trade me, just need two nuts like the one on the Rt
Try at repco and mag&turbo they should have it
- Datsun Dreamer
- aka: Chris
Yup, Repco should stock them in packs of four nuts and four washers. Mag and Turbo may have a heap of the washers laying around. OR
Go to any tyre shop, and they'll be able to get just the washers in for you through BGWorldWheels. They should be about $1.80 each or something i think. (Only because of freight. You can buy them cheap, but then get charged $7 or $8+gst freight.)
- aka: Jas
Thats weird. Repco was the first place I phone, mayby just got the wrong guy there. Sounded like it was to hard for him or he did;nt know. Will go in, in the week and I,ll try Mag a Turbo. I also asked at Tony,s but they said they could get them.
- aka: leppa
repco are useless at the best of times. best to always take the part you want as a sample.
- Datsun Dreamer
- aka: Chris
Also, they are called a shank nut.
