i need to buy wheel nuts for the mk3s, they are the type that have half the nut turned down to slide between the rim and the stud. the ones i got with the wheels are the wrong thread so im on the hunt.
any info is helpful
Wanted...... ssr wheel nut sizing
1972 1200 coupe KB110
Re: Wanted...... ssr wheel nut sizing
FYI they are called shank nuts. You will need to measure the diamter of the hole in the rims and get them to suit. As there is no taper to locoate the wheel on the studs, they need to be a snug fit into the rim
awesome! thanks for that!beaver wrote:FYI they are called shank nuts. You will need to measure the diamter of the hole in the rims and get them to suit. As there is no taper to locoate the wheel on the studs, they need to be a snug fit into the rim
does anyone know where to find said items?
- aka: Braasy
Try Mag and Turbo warehouse. They're pretty reasonable on price, and if they don't have them, won't take long for them to get them in. Any wheel and tyre place should be able to assist, but that's where I went last and had good serviceluke wrote:does anyone know where to find said items?
- Braasy
- woodies72coupe
Luke. Pop over I might have a set that might fit!
- pl510
- aka: Shannon
The shank on the nuts that came with my Mkiii's is 17.2mm if that helps
