CRAIGS 510 1600
hsepwr
Datsun Nutter
aka: Craig
Re: CRAIGS 510 1600
Post by hsepwr »
Yeh was going to bring a few in once I have fitted mine, just want to see what they were like first, can get them for all sorts of datsuns and cheaper than what that guy is trying to get on trademe for them.
gingofthesouth
Site Admin
aka: Ging
Re: CRAIGS 510 1600
Post by gingofthesouth »
Registering interest in price of rear sway bar kit and pics for fitment :) I have a MadDat front sway bar.
torqued
aka: Adam
Re: CRAIGS 510 1600
Post by torqued »
Atn: Ging . those maddat ones they go around the front of the sump right? What are the chances of pics and measurements of that as well?
gingofthesouth
Site Admin
aka: Ging
Re: CRAIGS 510 1600
torqued wrote:Atn: Ging . those maddat ones they go around the front of the sump right? What are the chances of pics and measurements of that as well?
Roger that. Will put pics and measurements up in the next week.
hsepwr
Datsun Nutter
aka: Craig
Re: CRAIGS 510 1600
Post by hsepwr »
Fitted the front sway bar tonight was piece of piss and fitted up easy as. Looking forward to fitting the rear and driving it should make a huge difference.
hsepwr
Datsun Nutter
aka: Craig
Re: CRAIGS 510 1600 UPDATE
Post by hsepwr »
Fitted the rear swaybar tonight and it took about an 1.5 hours. If it was on a hoist it would be 1/2 hour. it is not a bad kit my only fault is that when the car is low the lowest part of the swaybar is only about 80-85mm f the ground but i could alter that to make it 100mm i think. cant wait to see the handling improvement.
Re: CRAIGS 510 1600
Nice!
No body roll for you!
brocky41
aka: Brocky
Post by brocky41 »
hsepwr wrote:Fitted the rear swaybar tonight and it took about an 1.5 hours. If it was on a hoist it would be 1/2 hour. it is not a bad kit my only fault is that when the car is low the lowest part of the swaybar is only about 80-85mm f the ground but i could alter that to make it 100mm i think. cant wait to see the handling improvement.
If you get pulled up on the street - "Because Racecar Officer"
But
If hit ripple strip = damage
Looks the ducks nuts though craig - will be even more on rails now.
hsepwr
Datsun Nutter
aka: Craig
Re: CRAIGS 510 1600
Post by hsepwr »
I love parts day, There was nothing wrong with what was in there but I wanted the autometer mechanical gauges as they are a little more accurate than the electric gauge/sender unit and less to fault out on them.
Also got a new Heavy duty clutch today and a new clutch master slave and braided line. I rung the guy building the engine and got an update on the motor build and I should have it back and ready to drop back in the car in about 2-3 weeks, im champing at the bit to hear it run again.
85_Z31
Datsun Master
Re: CRAIGS 510 1600
Post by 85_Z31 »
Fantastic work Craig, the kit seems quite well thought out apart from the height issue you have pointed out.
It looks like you could make the link rod 20mm shorter to gain extra clearance ? I like the bilsteins in there too, top choice ;)
