ca18de or similar sizing top feed injectors needed
need for the ga16de..... must be top feed......
1972 1200 coupe KB110
Re: ca18de or similar sizing top feed injectors needed
There was a Bluebird with a CA18 in it at Pick'a'part, might still be there?
- brocky41
- aka: Brocky
got 4 red CA18de Injectors for you here luke
- mint16
- aka: Brendan
Ive got four 330cc injectors from an sr20de wth fuelrail and wiring loom.
72 Datsun 1200 Wagon
- Kitch
Yes you are on to it with your sizing!
http://witchhunter.com/injectorcalc1.php" onclick="window.open(this.href);return false;
Nissan Top Feed Injectors
260cc / 175 WHP - Red CA18DE
370cc / 250 WHP - Cream CA18DET
350cc / 275 WHP - Green SR20VE 20V P12
444cc / 300 WHP - Yellow SR20DET (GTiR)
444cc / 300 WHP - Yellow SR20VET
Think those ones of Brockys will be perfect for your application
I think I am running 22Lb/230cc in my A14/15 setup, cant recall off the top of my head exactly, but I did static flow tests to get exact flow rates & dead times, for my "reqfuel" settings to preconfigure ECU setup / fuel mix etc. Anything over 120HP @ Flywheel would be a bonus, I would like to think I get 130HP from all the hard work, but wont get my hopes up.....
