another week of working mostly on other peoples cars, but managed a couple of hours today while waiting for underseal to dry on Lukes coupe, If anyone wants the underneath of there car undersealed, DONT RING ME, the job sucks in the worst way, took me an hour justto mask it up.
Anyway the exhaust part is now fully welded, and ground back ready for media blasting etc.
so I have started on the inlet side of things, this part of the equation is highly experaMENTAL I bought some side entry injectors although at the time I actually wanted top feed, but once I saw how the side feed ones were constructed I came up with a plan on how to make it all work.
I cut the fuel rails off the sides and bored out the pipe that was left in the body, then I extended the bottom of the injector housing with some steel tube, drilled some holes in the inlet runners, and slotted the holes to allow the injectors to lean back on an angle, once I had the injector bosses fitting in the slotted holes I fed a length of steel tube through the body of the injector bodys to keep it all aligned .
The steel tube was purchased from safe R brakes and my arse still hurts from the reaming they gave me with the price.
Once everything was in alignment I silflossed the injector bosses to the inlet runners, (silfloss is a form of brazing designed for steel,copper and Brass but flows more like a solder when at the correct temp.) Great for sweating injector bosses to inlet runners.
as you can see in the pics the tube has been removed from the bosses and will need to be cut to lengths and sweated between the bosses to complete the fuel Rail.
So now the injector bosses have been attached, the runners are on the flange, I will need to finish things up and install the injectors and then pressurise the fuel rail and test to make sure there are no leaks.
hopefully this will all work out as im not sure many (if any) people have actually gone down the road of welding their bosses to the inlet runners.
