Hey people I've got a few bits left from my fj20 days.
I have a crank shaft,still standard needs a regrind though.
A set of cam shafts and a inlet manifold and timing cover no oil pump could have more ill update if i find anything else.
Make an offer anything considered
FJ20ET parts for sale
Re: FJ20ET parts for sale
No cylinder heads?
- Newbie
Is this for turbo setup? I'm wanting to turb my fj20de and lookin for parts, how much you lookin for $$ wise?
No heads mate it is a turbo manifold with turbo on it too
- aka: Bede
How much for the camshafts?
cams are the same for turbo and non. the cam gears are different, even then i think its the exhaust one only...
Is the inlet manifold a turbo one? Do you know if it's off a DR or S12?
The inlet is off a dr30 the big manifold has turbo on it.
I was told buy a fj20 guy that the cam were not the same diff lift and duration i can ask a mate of mine ( Who grinds cams if and the differences are if that would help. $100 make an offer ?
and ive been told the opposite.chris_g1 wrote:I was told buy a fj20 guy that the cam were not the same diff lift and duration i can ask a mate of mine ( Who grinds cams if and the differences are if that would help. $100 make an offer ?
i can tell you i have compared my NA and turbo gears and they are different.
also depends on the engine too.
i have a new NZ NA FJ20e that only has different pistons,pulleys and rods. everything else is the same as a turbo one.
348" cam lift. 214 degrees @ .050" and 288 @ .010".
