Im after a Torsion bar (a la your ute/van) for converting into a swaybar.
I need something about 28-32mm in diameter (at the bar, not the spline if its bigger/smaller) and ideally 930mm long. With identical splines at each end.
What you guys got?
Wanted Torsion bar for use in making a swaybar
Re: Wanted Torsion bar for use in making a swaybar
PickaPart visit?
- aka: Nick m
will probably resort to that, but this was requires less lying in mud measuring cars. So thought i would try this way first!
