Garth's SR20 B110
brocky41
aka: Brocky
Re: Garth's SR20 B110
Post by brocky41 »
If its only on the back then you can use the spacers you have as slip on spacers, as long as they are up to 20mm thick. 25mm for bolt on.
My 120Y had 12mm slip on spacers that way (with longer studs that bart now has) on the rear made from flat alloy without the locating rings as factory the datsun drums do not have locating rings. Was certed in 2009 bu pretty sure its the same ruling.
You may need to cap screw those spacers to the drum (think euro eg opel vectra front discs that have the little screw to hold them on so the disc doesnt turn on the hub while trying to fit wheel bolts) - easy as to drill and tap the drum as your spacers already have xtra holes if you use them as slip on's.
Garth
Post by Garth »
cul8r wrote:Meant to be using small keeper nuts, and cut the remaining thread off so your wheel sits flush.
We dont sell them - Vaughan Motors in Timaru are your best shot.
To make them legal for cert, your wheels also need to hubcentric and the spacers need to be also. You'll need to measure the ID Of your wheel and OD of the spacer. Id of the spacer and OD of your hub, so effectively you'll have two sets of Centerbore Locating Rings
ok sweet as cheers man much appreciated ill have a look into it.
unfortunately brocky its my front wheels. back all fits fine over the brakes without spacers
Garth
Post by Garth »
The new garage...where a lot of shit will hopefully happen
gingofthesouth
Site Admin
aka: Ging
Post by gingofthesouth »
Garth wrote:The new garage...where a lot of shit will hopefully happen
So jealous right now.
2 doors
Post by 2 doors »
winning combination right there
Garth
Post by Garth »
Just need room for a ute, wagon and maybe a 2 door sedan ;)
Garth
Post by Garth »
Oh heya fellas. My names Garth and this is my picture...
This is a 6mm piece of steel. What I'm needing is something of similar shape but probabaly about 20mm deep, so for all you engineering chaps out there or people with random steel sitting around...needing 8 of these things or something similar. Could probably be made out of box steel etc
Beers, cash etc you know the deal
mitey1200
Datsun Dreamer
Post by mitey1200 »
Garth wrote:Oh heya fellas. My names Garth and this is my picture...
I have some old penny's u can drill holes through
Garth
Post by Garth »
mitey1200 wrote: I have some old penny's u can drill holes through
You reckon it would pass cert?
Garth
Post by Garth »
I guess it's about time for an update..as most of ya know I sold the turbos and brought some new wheels...brought ginges old starsharks and put my tyres on...so here's some pics. Also made some door cards...makes the interior look much more "nearly finishedy"
