DJZ's DR30 Skyline
Re: DJZ's DR30 Skyline
Tru dat, one pattern on the FJ24 head pictures I found the same (or very similar) but the other isn't. I specifically asked for FJ20 gaskets but I'll double check before ordering.
I did something I might regret and bought an old SK Sanyo DCOE throttle body kit originally meant for a 4AGE, now I just need an FJ sidedraft manifold and a plenum.
Pretty much the same as this:
That is super sexy, what size are the throttles? If you do regret it I know someone (me) who would be very interested in those!
They are almost exactly the same as the ones I used to have on the L31, I think SK Sanyo and OER are related, they are 45mm.
These are the OER ones I had on the old L series:
Nah, you don't wanna run those bro....
what length are the trumpets? i need 85mm or less (if u want to seperate)
1972 1200 coupe KB110
Hey man, that's just a sample picture above.luke wrote:what length are the trumpets? i need 85mm or less (if u want to seperate)
I bought some S15 non turbo front brakes for this thing, decided to try and get a warrant without swapping the front back to 4 stud. The S15 brakes are 5 stud vented rotors but with single piston calipers, need to bleed them tomorrow.
Also pulled the left hand tail light apart to try and get all the water out of it, got it fully apart and have left it like that overnight to dry out. Does anybody know where you can get that black sticky stuff like they put the plastic beneath door cards on with? The tail light was sealed together and on to the body with it.
That's probably the same stuff as windscreen sealer.
Sticky black shit, that never fully dries.
Try spraystore, or RJP. (Although I hate the fuckwit at RJP)
Got a warrant today, yay! Will swap the brakes back over to the GTR ones this weekend.
He mentioned minor play in the left rear wheel bearing which will be due to the worn stub axle, might have to try and find another pair for the next warrant.
- Datto_610
- aka: Greg
Sweet! Bringing it along to hanmer?
