1985 GB122 1200 Sunny Ute
- DATY12
- Regular
- aka: Kev
Re: 1985 GB122 1200 Sunny Ute
Go with the fins!
Datsuns I've owned
Datsun Sunny x 4
Datsun 1200 Sedan
Datsun 1200 Roadstar Ute-Current
Datsun C20 Vanette
Datsun Sunny x 4
Datsun 1200 Sedan
Datsun C20 Vanette
- Tony_Whenua
Spent all afternoon trying to put coupe rear brake boosters in. Had trouble putting drums back on after it and had to loosen the adjusters and handbrake right tension off. Is this normal?
Also have to bleed all four brakes now. How do I go about this?
rear to front, left to right?
- mitey1200
- Datsun Dreamer
Tony_Whenua wrote:Spent all afternoon trying to put coupe rear brake boosters in. Had trouble putting drums back on after it and had to loosen the adjusters and handbrake right tension off. Is this normal?
Yea that's normal. Have to have everything backed off to allow for new brake shoe thickness.
Usually bleed the wheel that's the furtherist away from master cylinder. Eg left rear- right rear- left front- right front.
- Tony_Whenua
Yeah but that's the thing, I used the same pads? Oh well, cheers, will get it bleed tomorrow.mitey1200 wrote:Yea that's normal. Have to have everything backed off to allow for new brake shoe thickness.
6 Days to GO!
- Tony_Whenua
loving the new fins!!
dirtyleppa
- aka: leppa
Pics you bum
- Tony_Whenua
Still need to grind a little more off the brake callipers and roll the rear guards some more AND TIGHTEN every nut and bolt that I've touched.
Looks wicked man!
Was great to meet you the other day and glad the fins have gone to good use!!
- gingofthesouth
- aka: Ging
