4340 threaded sleeves with locknuts and bottom seats. sleves were made for b110 struts and so are a slip fit.
250lb springs pretty solid for the street, if you are planning on getting low/engine conversion/maybe a few track days these will be for you. keepers and tophats will be included as will stock b110 strut tops.
will be welded to a set of coupe struts, these come with no hubs/disk or calipers.
set of monroe gas shocks which are nice and short and will suit the springs.
The struts can be shrtend right down if you after epic slam or I can make up a spacer for the bottom of the shocks for more sensible ride heights.
so basically you tell me how low you want the adjustment range and I will build these to suit you.
Tell me what its worth
also reason for selling is that I am looking to modify a set of s13 rear coilovers for the job. this way I get a stiffer spring, the ability to go so low that I will graderblade the road with my cross member and have the bonus of adjustable shocks so I can screw up my handling 19 types of wrong.
