Thought id better update....Getting my modified loom back tomorrow, a guy named Hamish does them through trademe.
Hes an auto electrician doing perkies it seems.Hopefully for under $300...
Still need to make a bracket for the oil cooler few photos of how far i've got...
Intercooler is now in its proper position aswell.
Caallym's CA18 1980 Sunny Sedan
- Newbie
Re: Caallym's CA18 1980 Sunny Sedan
Nice. You could always just get the stainless ones shortened of course, they'd last a lot longer than rubber. I could even do it if you paid the freight....
- Newbie
Meaning the oil cooler hose?is it crimped on or?Would be sweet if you could, flick you some heineken money for your troubles...
- Newbie
Well its been awhile...
Have been busy as with everything but the Datsun so have taken some time off work to get into it.
If all goes to plan... will be fired up this month, pretty excited!
Wiring is going to be started next week so may have some questions...
Hope i have some hair left in the end.
Few pics of latest progress:
- Newbie
Few photos of what i've been up to...
- Newbie
Have got some new wheels to roll on untill i find some genuine SSRs.
Dirty DTMs, These are +15 15x8 all round.
They actually clear the 4pots with ease compared with the 0 offset Work replicas.
Still using 15mm spacer for now gives almost 10mm clearance.
Will be getting some Wilwood 4piston before cert as are 15mm slimmer per side should be able to run a reasonable offset without a spacer then.
- Newbie
Have also started on the interior somewhat, have picked up a few necessary gauges.
Still need to get an innovate Wide band Gauge...
Center console is coming together, will be wrapped in a decent vinyl or carpet of some sort.
Would've been proper fucked without a Multitool i must say.
