b310 auto driveshaft
funkydato
- Datsun Dreamer
- aka: Pickles
anyone got one, mine making noises in reverse, can you replace the knuckles at end? think that is what it is, took it out and does not turn freely, quite tight
81 b310 Dato (everyday drive)
81 b310 Dato (in storage)
79 Sunny (project on-going)
Ministock (Green, 1200)
Rusty
- aka: Ryan
Re: b310 auto driveshaft
On the manual ones you can't replace knuckles. I haven't seen a auto sunny in ages
funkydato
- Datsun Dreamer
- aka: Pickles
and the manual ones don't fit either, the shaft on a auto is bigger, dam it
- Kitch
do you know if 210 ones suit?
I have one left over here from when I did manual conversion on 120Y
funkydato
- Datsun Dreamer
- aka: Pickles
Still require one if anyone has or knows of one
- woodies72coupe
I know Hayden did change his 310 to a Manual if that helps.
I have no Idea if he used it or changed it to another.
I have 3 driveshafts here. But think they are all manual. Welcome to have a look.
Sent from my iPhone using Tapatalk - now Free
I'm pretty sure auto 310 tail shafts are rebuildable.
Take a look under it, and you should be able to see pretty quick if it is or not.
