As per title after a pair of the rubbery foam bump stop rings, that go on the front shock shafts.
Need to reduce the clunking in the 310!
WTB 310 Sunny front shock bump stops
- mint16
- aka: Brendan
Re: WTB 310 Sunny front shock bump stops
Autolign bud.
72 Datsun 1200 Wagon
- brocky41
- aka: Brocky
Make sure its not the sway-bar overextending itself into the chassis (in the middle of the bar in-between outer links and first 90 degree curve, this used to happen on the Y and the 1200.Kitch wrote:As per title after a pair of the rubbery foam bump stop rings, that go on the front shock shafts.
Otherwise we sell them at BNT aswell - be closer for you down there
