Hey guys, this is my current project and first datsun. I got it as an half finished job that was neglected for about 6 years, so I feel now is the time to life back into her.
The engine in it is a modified a12, I believe it has a fast cam and double valve springs and side draft webbers which needs tuning.
The engine bay has been deloomed and painted jet black with every hole is welded, battery in boot, wiper motor under dash
The front seats are recaros which have been retrimmed in black suede and tan vinyl.
Has an msd ignition, msd coil and an electronic dizzy. Holley fuel pump and regulator.
The suspension is all modified, twin sway bars on the front, sway bar rear, large diff (form a skyline i think) and bigger brakes. All the suspension came of a track car.
Has a line lock kit installed, electric window, remote entry, switches to start it, a factory rev counter running off the msd...
Has modgies but they have some rust,
also comes with 25mm wheels spacers to fit all types of wheels
The interior is stripped i have a recaro backseat i was going to put in, but that involves to much thought so ive sourced a std seat
and the best thing ever electric windows
The engine going in..
FULLY MODIFIED A15 FROM A HILL CLIMBER! kelford cam, daihatsu charade turbo pistons, ported /polished and planed head, and heavy duty clutch and lightened flywheel.
currently getting rehoned for the piston rings
Spares
factory a12 (has a fast street cam but that dosnt make any difference unless you change the head) has the head of but can easily be reassembled, has heavy duty exedy clutch.
2x 4 speed gearboxes
My B310 Project
My B310 Project
- damz721
- aka: Damian
Re: My B310 Project
Sweet as ride bud looks like shes got some serious work done to it! would be keen as on more details on ur a15 build as im about to do one
- 77 B210 S/W
