You might has well have written:
Wanted to buy good condition set of hens teeth.....
Garth's SR20 B110
Re: Garth's SR20 B110
Hard to find now days I have a set or two good luck.
You should part with one of your setsmy1200 wrote:Hard to find now days I have a set or two good luck.
hehe whooops
YES FULL PINE!
haha straight away ofcourse i have run into clearance issues with my rear brakes but should be an easy fix. now just gota find some sweet as tyres for them.
definitely going to be looking crazy tough once they are on!
what size/width are they? they look good
13x7 and 13x7.5, -3 and -9 offset. i can clear my rear brakes with about 8-9mm spacer on the rear but its pushing it a wee way out the back, will get my gaurds pumped a bit when getting the rust cut out of them.. might give the calipers a shave with the grinder tonightbuzzy wrote:what size/width are they? they look good
- darrenwilson
YEAH white suites it better
Long Live Datsun 1200
finally got some rubber for the new rims!
