Yay, ECU guy diagnosed a faulty MAP sensor - so I am not crazy after all....
going to get latest code uploaded, sensor replaced, default tune setup, and
hopefully new Bluetooth transmitter installed
- joelbrown
- aka: Joel
Re: Kitchs 1200 Coupe - First Drive!!!
Thats good news dude, keep up the good work, not far to go now.
Best of luck for the rest of the build,
Its guna be magic seeing this complete
1990 1200 ute
- Kitch
Here is an update (first in 3 months)
Just so Greg feels better, here is my list of 'things to do' before Akaroa ……
? Rear axle bump stop mod’s / fitment or source new
? Steering box main nut – need to get die set to repair thread
? Steering arms etc – fit split pins, tighten bolts, grease up
? Drop fuel tank & Mount battery box with M8 threaded rods & Nylocks above
? Drive shaft hoop fabrication & drill new fixing holes as required
? Modify/replace Gearbox Cross member mount
? Wire up new wasted spark Coil pack
? New Fuel pump remote relay wiring & install
? Once ECU returned test run engine up again, and set base tune, test tacho etc
? New Bolts for steering box & idle arm etc to mount through chassis rails
? Procure filters to suit T3 ITB trumpets
? Prep / strip down for final paint job!
? Rust kill & dress around rear panel sub frame bit
? Drivers Seat mount repair, needs re-welded to inner sill
? Lurethane roof bar to roof, also need to lurethane rubber firewall cable grommets
? Door & front guard repairs / mock up / guard flaring
? Complete Shell, door & guard exterior paint job…. (pending lotto win)
? Paint behind front valance
? Paint new skuttle panel grills
? Paint mirrors, tail light surround inserts & grill
? Dynamat to inside of front doors
? Dynamat to rear guards, beaver panel, rear seat area & rear wheel arches
? Foam sound proofing to roof, inner guards etc
? Fit out doors completely pre fitment (all mechanics & new seals & glazing)
? New Handbrake lever plastic grip fitment
? New earth strap for relocated battery
? Fit up ciggy lighter or blank off with grommet
? Install new Bonnet pull lever & cable
? Conduit LH & RH fender looms & finish off light wiring, new plugs/terminations & repair faulty light circuit
? Custom Gearbox reverse switch install & wiring (servo switch under centre console!)
? Make new custom Seat mount adaptors (240Z seats to 1200 rails)
? Procure new carpet kit, trim & fitment
? Source new (impossible) or overhaul new sill Trim plates
? Kick Panels – procure new or custom make (must look OEM)
? Dash final installation & heater mounting etc
? Buy New Seatbelts & have front seats reupholstered (and possibly rears)
? Upholster boot false bottom panel with new vinyl
? New Hood lining acquisition and install
? Fit new window rubbers, bailey channels, stops & grommets, seals threshold opening seals etc
? Fit NOS badges, vents, lights, fender mirrors, wipers & bumpers etc
? Install all glazing & repaint/polish trims/surrounds as required
? Wheel alignment
? Tuning….
? Cert / compliance
? Reg / WOF & insure!!!
? Do a skid
? Get pissed
? sober up
? Drive to Akaroa in October 201(?)
? Wheel alignment
? Tuning….
? Cert / compliance
? Do a skid
? Get pissed
? sober up
- Datto_610
- aka: Greg
Hahaha good stuff Kitch we both better get cracking aye!
- damz721
- aka: Damian
Now thats a detailed list! time to get cracking then? Be well worth it in the end!
- 77 B210 S/W
- Kitch
Righto, scraped the dust off the coupe this weekend and actually did some work on it!
Big thanks to my 7 year old (Will), who was eager to earn pocket money by helping Dad out working in the garage.
> I got the steering box removed (need to get the bottom thread cleaned up)
> Finally finished laying my second pack of dynamat superlite down (just have doors left to do)
> Drained water & removed heater box assembly (I have to do some remedial wiring behind it after a fry up last year)
As per most 'long term' builders, I get fizzed this time of year, thinking I can have car complete for next summer....
a visit to the classics @ levels today was motivating to!
- Kitch
By the way the silver patches are mass loaded vinyl layers velcro dotted over
the top of the lift & EFI feed pump to aid with shutting up those noisey things!
- Kitch
Picture-less update, don't expect any comments, just writing this for my own
benefit to keep myself thinking I am progressing with this damn coupe!!!....
Mocked up front seat mounting, now using the Z rails rather than the b110 ones,
should be a bit simpler adaptor the rails to the floor mounts, rather than adapt
the B110 rails to the seats. Also have brought another set of Z seats that will
hopefully be OK in the short term, then I can get my scruffier ones overhauled
off line when I can justify it / afford it.
Removed wiring from firewall to boot area. Ran 2x new heavy (8ga) cables through
pillars & roof edge cavity from boot to the firewall, with new dedicated feed to
the headlight relays and also general 12V power supply network.
New Fuel start signal from relay to new 50A heavy duty relay I am mounting in
behind the rear tail light plastics. Upgraded all the fuel pump 12v feeds to heavy
oxygen free 10ga wires minimum. Awaiting a gold 30A fused distribution block to
turn up which will feed the new 12V circuits. Fastway have managed to take 8
days so far getting it from chch to Timaru.....
Should have the ECU back from Scott @ Embedded Design next week. Should be
good to go with new onboard MAP sensor, new ITB tune base maps, tacho circuit,
and new bluetooth adaptor for Android on the fly megasquirt tuning/diagnostics:
https://play.google.com/store/apps/deta ... dash&hl=en" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=kR3cg38tGOE" onclick="window.open(this.href);return false;
dynamat is looking mint kitch! I know its probably back in your thread a wee bit but im being lazy...roughly how many extra kilos do you think you have added with the dynamat and how much did it end up costing?
I am thinking I might do it to my sedan to get a bit more comfort out of it...and seeing I don't really have many issues with power to weight....
- Kitch
I have put 1.5 packs of superlite (12 sheets or 48ft2 per pack) in the coupe to date (about 8m2)
not 100% sure off top of my head but think its 1.2-1.5kg per m2
I have also added mass loaded vinyly layer (the heavy silver stuff you see on floor) that is heavy!
In reality I have probably added a total of 20kg for my sound proofing by time I have finished.
Not ideal for power/weight but should make driving experience more pleasurable
