Engine sorted today so im going V6 (vg30) plan now is to dump the efi shit and use a 500 holly or similar .still in need of a gearbox .Havnt started the rust work yet I hope to find time this weekend
Also if anyone see vg30 inlet manifold like this plz pm
jacked the old girl up to find the springs on all four aren't even close to being captive as not likening the welds on the strut will need rewelding at a guess these like modified s14's doesn't seem to be much on the net about this mod (not that I looked that hard)
sump is need a lot of mod's to get the engine sitting lower
this could be a problem oil filter and steering box
removed the shit im not needing and stuff that needs modifying .bit more room now
with the flipped cross member there is heaps of room for front bowl sump
Ratty 510
Re: Ratty 510
at the very minimum, the welds on those struts will need to be crack tested.
Re: Ratty 510
Fuck all of a update still working on sump as i cock the first one up.But ive found the wheels (the size anyway) 15x8 steels im 90% sure they will fit just by knocking the lip of the guard out a bit.There is abit more room for the rear rim to go in
just need to find some centres to suit
- gingofthesouth
- aka: Ging
- DylPhil7
- aka: DylPhil
Re: Ratty 510
Following thread haha! looking forward to seeing steelies
Re: Ratty 510
I found some centres tho im not 100% sold on the look TBH
not much better black
anyone have any idea of what other centres I could use?
- DylPhil7
- aka: DylPhil
Re: Ratty 510
I like them aye
- darrenwilson
Re: Ratty 510
Great Work hope to see it rolling soon I think the black don't show how deep they are.
Long Live Datsun 1200
- mitey1200
- Datsun Dreamer
Re: Ratty 510
Could get some custom centre made. Just take a pattern you like to Royce Clive engineering or someone similar. Cheap as chips too. Had to get some custom 15x6 made for work. Was around 200 for a whole wheel so a centre should be at least half that.
This guy did it with this Cressida. (Steel)
