1977 B210 Front calipers
all your DIY needs
damz721
aka: Damian
Post by damz721 »
Any ideas? Please apart from buying new wheels??
Rims are wrong offset.. Have 5 mm spacer on front hubs and 1/2 worn pads...
Went to fit new TRW pads but didn't realise it pushed the calliper slide housing out even further.
Are there any other Nissan callipers that will bolt straight on.. that may help?
Example 140j,180b etc that have narrower outer slide bracket?
Hoping some one can help????
With new pads need about 15mm clearance.
Thanks Damz
- 77 B210 S/W
beaver
Datsun Nutter
Re: 1977 B210 Front calipers
Post by beaver »
I dont think there are any bolt on calipers.
I had the same issue, but didnt need as much room so took about 8mm off the outside of the caliper bracket (where it fouls). For 15mm Id just run a spacer, or look into the s13 caliper swap and see if that will work.
