1985 GB122 1200 Sunny Ute
Tony_Whenua
Re: 1985 GB122 1200 Sunny Ute
Post by Tony_Whenua »
A few goodies turned up.
Will hopefully have it on an engine stand on Tuesday and see if I can figure out what has been done to it
dirtyleppa
aka: leppa
Post by dirtyleppa »
Give us a yell if u want j hand
damz721
aka: Damian
Post by damz721 »
Looking real good on the new wheels :thumbsup: !!
- 77 B210 S/W
dirtyleppa
aka: leppa
Whats the b1600 looking ute doing in ur garagw instead of ur ute
Tony_Whenua
dirtyleppa wrote:Whats the b1600 looking ute doing in ur garagw instead of ur ute
Yeah I bought it for my xmas present haha
:lies: slash dreams
But of an awesome update ... little progress but I feel like I've achieved greatness. \
Managed to get it up by myself while the Mrs watched. Seems a re-occurring issue :|
Leppa, I would be keen to get your ideas wisdom help etc on Thursday if you're still keen?
Maybe start breaking it down?
Tony_Whenua
Leppa came around over the weekend and we stripped that a12 engine. Pistons had broken top rings and the dizzy cog on the cam is chipped. Leppa seemed to think that the cam hasn't been worked which kind of sucks but we didn't have any measurement to compare.
Any body know the original cam measurements.
When measuring the lob do I measure the lob lift and base circle together?
Also on the cam there is marked "CSL 132F 03 - MATT"
Thinking CSL = CSL automotive?
Leppa is a machine ... engine was stripped in seconds.
He's good at taking things apart all right! :lol:
Tony_Whenua
EUQ523 Datsun 1200 (Current cash available $2,000 but more to go in)
• Engine block cleaned, pressure tested. $? (700)
• 2nd hand cam and cam grind $260
• New engine seals and bearings $?
• New gaskets $?
• Head studs $180
• Alternator $(use current one?)
• Water pipes $(use current one?)
• Timing chain $25 (or use old one)
• Dellorto refurbish/tune $
• Fuel lines for electric pump $
• Tune $
• B210 sway bar $110
• Torsion, sway, bottom arm, ball joint bushes $
• Brake seal and pistons $
• S13 wheel studs and spacers $
1. Engine block to Nelson (unsure which shop)
2. Cam sent to Kiwi Cams (p north)
3. Measure previous pistons and bore dimensions.
4. Order parts for re-build
5. Clean all parts down and polish
6. Re-build front suspension
7. Rust repairs in Chassis
8. S13 wheel studs (same same but longer?) and legal wheel spacers
9. WOF
10. Engine swap
11. Tune
12. REGO
chris_g1
Post by chris_g1 »
Hi Tony,
Comprehensive list, More money needed at a quick glance,
Also some of the improvements will need certifying.
Up our way that is a minimum of $500.00.
My advice would be do all the certifiable things at the same time and THEN get certified ONCE.
kobyn
Datsun Mad
Post by kobyn »
Head shop p north are really good sent my Datsun heads cams to them Brendon hartleys dads shop gc also csl cams is good place also in pamly
