Hey guys I'm could be after a right suspension strut for my car.
I have a 1981 Datsun Sunny GX b310, if you after more info just ask. I would profer it be South Island to make costs bit cheaper.
Right Front Suspension Strut
- Kitch
Re: Right Front Suspension Strut
you after the insert or strut housing itself with stub axle etc?
Sorry warrant man got it wrong, it's a shock that I need
- Kitch
I have some surplus original oil filled type 310 strut inserts if they are of any use to you?
Yeah it could be. You don't think you could put a photo up so I can make sure it's right ?
- Kitch
Do you have oil filled inserts or gas?
If oil filled, you can overhaul what you have I guess - or best to throw an aftermarket insert in each side.
Really important for handling that these work together, a Pair of inserts would make a huge difference to the handling of the car, and it's rideKitch wrote:Do you have oil filled inserts or gas?
It is oil filled. How much are you after for the right front one ?
- Kitch
Why did it fail WOF?
Can you not just strip down your one and clean up, put back together and refill the oil with ATF?
My spares are stripped down, so would be no difference to re-using what you have, unless the dampening valve has failed?
I'd just buy new gas inserts and be done with it.
It'll really make it drive heaps better too.
