1600 brake upgrade
- aka: Jordan
1600 brake upgrade
Selling as i have gone with a different set up. A pair of wilwood dynalite 4 pot calipers and brake pads, never been used or put on a car, worth $500. A pair of brand new brake discs, have a bit of surface rust from sitting around, and a pair of used brake discs that probably just need a slight skim to look brand new again, measure 250mm across. And a pair of brackets that bolt to your factory caliper bolt holes and then the wilwood calipers bolt to the next set of holes. Wanting $450 for the lot. Was told that this set up is for factory 1600/510 struts. Would be an awesome upgrade from factory brakes
- aka: Jordan
Re: 1600 brake upgrade
Still for sale
any idea if they would fit under 13" wheels?
- aka: Jordan
No I don't sorry but i know that they fit under 15 inch rims
- gingofthesouth
- aka: Ging
I would be so keen if:ginga-dato wrote:No I don't sorry but i know that they fit under 15 inch rims
1. I was running standard shocks (got R31 in at the moment, but brakes foul rims. Going to try 280zx struts I have next).
2. I knew my starsharks would clear them.
3. Most importantly, I wasn't fleeced of all my money over the next 3 weeks by my wife for my sons 3rd birthday lol
- aka: Jordan
Yea trying to sell them for standard struts, when not many people stick to factory 40+ year old struts, is becoming a bit of a challenge. The brackets might bolt to other struts but i wouldn't know
would they fit 15" rims with say 2 inches clearance? if your happy ill come round sometime and check them out? if you haven't sold them when I get back from aus on 12th may ill hit you upginga-dato wrote:No I don't sorry but i know that they fit under 15 inch rims
- aka: Jordan
I wouldn't know how much clearance exactly. The guy that i bought the set up from was running the same rims as me which are 15x7 konig rewinds 0 offset. Give me a txt when you get back
