Engine upgrade
all your DIY needs
Re: Engine upgrade
Having built a pretty ruthless a series engine, and knowing all the pitfalls that go with it, I wouldn't hesitate to go for a twin cam turbo engine if I was to do it all again.
So much easier to make power reliably with a modern forced induction engine.
kobyn
Datsun Mad
Engine upgrade
Post by kobyn »
A series on meth I see mini sprints do it anyone done to a street car yet ?
Loganw
Re: Engine upgrade
Post by Loganw »
Any chance you could list out some of those pit falls Bart?
My goal is to build a screaming stroked A series.
Re: Engine upgrade
The factory pistons aren't up the the task. The ring lands tend to get a bit loose.
By the time you build a strong reliable A series, you could have easily bought a CA or SR. And a mildly worked turbo engine would easily exceed the power output of a pretty wild A series.
Re: Engine upgrade
M1SSI0N wrote:It's more or lease going to come down to which is going to how much work in the two different motors. Ca18 is always a choice. Not crazy but still enough grunt to have some fun.
Kidds VG30 eating 510 with the CA in is very impressive, I can only imagine what a worked CA would go like in a 1200, but work wise surely an A series build is way easier. Oh and the Twin sidies or ITB scream, Mmmmm
Re: Engine upgrade
Depends on what you really want most I guess.
Damon's ute is a classic example of a well built A15 that is no end of awesome. But still a street car with it.
Re: Engine upgrade
Loganw wrote:Any chance you could list out some of those pit falls Bart?
I haven't built an A15 or a stroked A Series but I have built and thrashed a Std Crank, rods, front dissy, cast piston 1300cc A12, for 10 years this engine won club champs, hill climbs, competed in Rallies and Endurance Races and never complained, apart from when the fly wheel bolts shore off, the ensuing free rev was a thousand or two too many, but 4 valves and 6 Flywheel bolts later and it was all good. I recommend ARP flywheel bolts, and even dowling the flywheel.
They are a sweet wee engine that loves to Rev. Reliably. Rewardingly.
Do it :burnout:
