Datto_610's C31 Laurel Pillarless Sedan
Datto_610
aka: Greg
Post by Datto_610 »
Went in for warrant today, not the best result but nothing too major!
*Horn to work (took connections off and sprayed crc on them works now! :thumbsup: )
*Adjust steering box play (the fella said he wasn't too concerned about how much I adjust out as long as it's better than it was)
*A few holes in the exhaust need filling up (anyone got a mig I could use?)
*Worn right rear brake hose (will buy a new one)
*Brake ballance uneven (mentioned I should just bleed the brakes and replace with new fluid)
So not too big a list to cross off before next weekend!
2 doors
Post by 2 doors »
I have a mig, but you will need to come to me, I also have a tig and plenty of sheetmetal for patches if needed
Datto_610
aka: Greg
Post by Datto_610 »
Thanks for the offer Wal but Chris Wildey sorted me out yesterday morning :D
Was only two small pin holes so didn't take long at all
Chris also helped me with adjusting the steering box seems much better now! Got a new brake hose yesterday too so just need some fluid and bleed the whole system up and done!
Grab a big as cattle Syringe or gearbox fittery thing to drain the reservoir before you start, and replace with clean fluid, then when you have clean coming out at the wheel you are done.
I think Karl is going to lend his his Air bleeder. No pumping required. Just pull the trigger, and it's done.
Best solution. :mrgreen: would love one
Datto_610
aka: Greg
Post by Datto_610 »
Yup yup got that from Karl yesterday and borrowed ,y brothers compressor. Got all the old fluid from each caliper and drum so M/C is completely empty. Went to fit the replacement hose which when I got it from Butlers on sat arvo said to the guy it looks way different to the one on there (I even took in a sample off my disc brake subframe!!!) So yeah pretty peeved and don't want to muck around getting it to fit so will take it back and get a refund grrr
It's the same thread but it doesn't fit onto the brackets on the arm and body
Take it back, and take your sample to safeRbrakes. They can make hoses for not too much money. especially one that short.
Datto_610
aka: Greg
Post by Datto_610 »
Took back brake hose today got the right one! Fitted it up bled brakes with Karls vacuum bleeder went in for wof re-check passed! Gave the inside and out a good clean today so I'm all ready for this weekend. Can't wait to start driving this again. With the new door window seals there is no wind noise soooooo quiet! I was going to take a photo of the wof sticker but it's right under the tint band and it's super hard to see hahaha
All I need for the manual swap is spigot bush, new slave and rubber clutch hose. Will also get new tie rod ends for each side and fit powdet coated steering components. I'm going to look into getting an alloy rad as the core in mine is poked much cheaper to get an ali rad off the tard than a re-core!
Karl
Post by Karl »
classicdat wrote:Best solution. :mrgreen: would love one
it was the best $71.90 I had spent in a while
http://tradetools.co.nz/products/3025460" onclick="window.open(this.href);return false;
