Datto_610's C31 Laurel Pillarless Sedan
- Datto_610
- aka: Greg
Definitely going to invest in one in the future!
- Datto_610
- aka: Greg
So been getting a few things sorted for the manwell conversion. Cleaned up the rust off my flywheel bolts and sprayed them with CRC in a snaplock bag, Bart also took my flywheel in to get machined(chur Bart!). Also on Bart's recommendations I have taken out the front and rear seals from my gearbox and the speedo drive o-ring to be replaced with new ones. Finally managed to get some 910 front springs from Skutaman to lower the front but they are a bigger diameter than the R30 springs :/ I may just cut the ones I have and reshape the end, depending on how much time and $$ I have left before the Akaroa cruise. So far I've dropped out the driveshaft and made a start on dropping the gearbox things are happening!
Looking good. did you want my ramps again?
There is another seal inside the speed drive Greg.
- Datto_610
- aka: Greg
Na, my new jack coupled with axle stands gets it up pretty high.classicdat wrote:Looking good. did you want my ramps again?
Really? how do I take that apart?Bartman wrote:There is another seal inside the speed drive Greg.
Also forgot to mention that the clutch fork boot is stuffed will go visit Scott for a new one
From memory there is a roll pin that you knock out then you can pull the shaft out and it's inside the housing.
- Datto_610
- aka: Greg
Yeah had a gander this arvo, will need to find a very small punch to tap that out!
And that seal leaks like a bitch when it wants to as well, I think it's a cup shaped one. I've got punches, can head around Friday after work with some springs for you to try too if you want.
- Datto_610
- aka: Greg
Oh mean! That would be choice bro.
- Datto_610
- aka: Greg
Tidied up my gear stick as it looks like at some point the rod has been been bent a bit and the threaded part welded back on. Also re-chromed it because I could(although not for long)
Saw Brock this afternoon and got a new clutch slave, spigot bush and front and rear gearbox seals. Will have to got to Saeco for the speedo drive o-ring and seal.
One slight issue I've encountered though is the new slave doesn't come with a pin to engage the clutch fork, I thought that the one from the R30 I wrecked would have one but nope not even a boot so anyone got an old slave cylinder lying around I can pinch the pin off??
