Guys,
My boot lock has pretty much pooped itself after intially being quite stiff then after much trying to turn the key as it became stuck something internally in the barrel seems to have moved and even after spraying the hell out of it with CRC/WD40 while the key goes in and turns it seems to be unable to open the locking mechanism.
Anyone ever come across this or have any suggestions as to how I could get the boot open without butchering it?
Dave
Stuffed Boot Lock
Re: Stuffed Boot Lock
You should only use dry lube on locking barrels.
Dave, Hopefully it is like a 510 and you can remove the back seat and perhaps rear parcel tray and get to the rear of the mechanism enough to trip it open. I suspect part of the lock mechanism has collapsed. I have opened up lock barrels but it requires prising the outer cover off with out butchering it too much. At this stage I would remove the damaged parts and reassemble the lock with slightly reduced security and use this lock on the petrol flap and promote the petrol flap lock to the boot. Good luck, Cheers Andrew
70 510 rally car rebuilt and prepared as a classic race car
68 510 sss, retired rally car, currently a bare shell being restored
72 510 sss, awaiting restoration
72 510 sss, retired race car back on the road sold to my son
The fuel tank might hamper access a bit.
I should have a spare barrel Dave, but no key, hopefully we could rebuild it to suit your key, I don't think they are sealed and unserviceable. You may need to do the old screw driver as a huge Key trick.
Thanks Guys.
Thanks for your replies.
Yes, I have considered the big screwdriver trick but that would have to be a last resort. Might call a locksmith tomorrow and get their thoughts on it.
Dave
Dave
Andy was quite correct- same process as the 510. Took the upper back seat squab out and we used a long spanner to flick the little lever that opens the mechanism. Thank God for that!
Dave
Dave
