L28 flywheel to take the 240mm clutch
rob240z
Datsun Dreamer
Post by rob240z »
As title says i'm after an L28 flywheel that takes the bigger 240mm clutch, currently have the 225mm and have gone through two clutchs in 800k's hoping the bigger diameter will solve my problem. be good to get one asap so i can use the car for labour weekend
71 240Z
78 810SSS
DJZ
Re: L28 flywheel to take the 240mm clutch
Post by DJZ »
RB ones fit and will be a lot easier to find.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
Ivan
Datsun Nutter
aka: Ivan
Post by Ivan »
Well that's handy to know so would an RB flywheel fit an L28? I will check that out tomorrow
Datsun 260c
rob240z
Datsun Dreamer
Post by rob240z »
Do they bolt straight on? no mods at all? will the stock starter work? and are they all the same RB20,25,30 etc or is there a certain one to use?
71 240Z
78 810SSS
DJZ
Post by DJZ »
Bolt straight on, you may or may not have to shim the ID where it locates on the crank, I never did though, I used a 240mm RB30 one on my old 3.1.
RB's have the same clutch sizes, 225mm & 240mm, most people refer to them as 6 bolt and 9 bolt flywheels, that's the number of pressure plate bolts. Most 2 litre non turbos will have a 225mm clutch, almost everything else should have a 240mm but best to double check before buying one.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
DJZ
Post by DJZ »
Almost forgot, there's a very good chance you'll need a shorter release bearing carrier as the 240mm clutches are usually taller.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
rob240z
Datsun Dreamer
Post by rob240z »
Cool thanks for that i'll have a look into it. what did you get a shorter carrier from?
71 240Z
78 810SSS
DJZ
Post by DJZ »
It came off the RB30 gearbox, if you can get the one that matches the flywheel you should be sweet.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
68p510sss
Regular
aka: Andrewj
Post by 68p510sss »
Also check the ring gear diameter my Stagea RB25det has a starter motor with a reduction drive. It is not compatible with non turbo starters
70 510 rally car rebuilt and prepared as a classic race car
68 510 sss, retired rally car, currently a bare shell being restored
72 510 sss, awaiting restoration
72 510 sss, retired race car back on the road sold to my son
DJZ
Post by DJZ »
Oh and stay away from anything with a pull clutch.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
