Hi,
Im looking for the centre rod on the 620 Steering (the adjustable one) sorry, not sure of the correct name. I don't need the ball joints. just the rod itself.
WTB 620 steering arm
Re: WTB 620 steering arm
Im assuming you mean assembly #12 in this diagram??
If so, just get a couple female tie rod ends to suit, and a rod to length and get the ends threaded
I have one of those spare.
How much would you want for it?Bartman wrote:I have one of those spare.
And yes it is #12.
Im probably going to use it to make 2 adjustable tie rods.
Make me an offer?
surely adjusting one arm is easier than adjusting two?
It may cost a bit to post due to it's length. It wont weigh too much though.
$20?
Ill still be able to adjust as normal but then also each one individually. 200% more adjustability haha.
Sold.
I'll try break it down this weekend, and figure out a way of packing it.
Maybe one of those post tube type things?
sounds good man,
Can txt me on 0276340482
I had a look at two of mine today.
The 1978 truck had both tie rods unadjustable,
The 1973 truck had one adjustable, one not.
