Hi all
im looking into changing my 620 ute from drum brake to disk brake.
Unfortunatly it is kingpin at the moment and i havnt had much success finding balljoints for it from another 620.
Im currently looking at modifiying some 5stud disks to fit as a last resort.
Does anyone have any further ideas or possibilities??
(Wheel size and stud pattern doesnt matter)
620 disk brake conversion
dirtyleppa
- aka: leppa
Re: 620 disk brake conversion
Why not see if navara stuff can be used?
Havnt got any navara stuff on hand but i am also looking into it
If it helps someone did a disc conversion on my 74' 620 at some point, its still the kingpin setup and factory arms,
as far as I can the the brake setup looks like factory bolt in parts, from what I have no idea thou. Ill take some pics in the next day or two of the setup and post them you might be
able to work out the what its from
Bart would be the man to ask I think.
My flatmate jeremy did it, used 720 bolt in parts.
1972 1200 coupe KB110
Easiest way is to find late 620 ball jointed arms. Then d21 navara hubs and stubs can be made to work.
Thanks for all the replys guys
i was looking at bearing sizes last night on the skf website, when it dawned on me that the inside diameter on r31/z31 bearings are quite close.
It looks like the outer hub bearing inside diameter is 1mm smaller than a 620 outer bearing. (19mm vs 20mm)
wishing i didnt get rid of my old r31 hubs now
can anyone give me the stub size/length for a r31 or equivalent??
or hook me up with a hub to try out?
