Hey, anyone in chch able to give me some advice on adjusting the rear drum brakes and bleeding brake lines? I have a '76 180b wagon and am trying to get back on the road again. The asian WOF place said the brake pedal had to much play and handbrake was too loose, so i think the aforementioned procedures will sort it out. Does that sound about right? Car was parked up for 2 years as have been studying at uni.
adjusting brakes 76 180b
Re: adjusting brakes 76 180b
You need to un-adjust the handbrake cable, and then adjust the rear shoes out till they're just touching the drums. (But not dragging hard out)
Then re-adjust the handbrake cable.
is the car in CHCH, or Oamaru?
in christchurch, in ilam.
What tools, jack etc have you got.
Not too big a job, just as Bart said.
The adjuster on a 610 will be inside the backing plate and accessed from behind through a rubber bung I'd think, just turn it, it will make a clicking sound as the ratchet clicks over the teeth. Don't over tighten as they can be a pain to back off.
It may pay to remove the drums first to inspect the condition of the breaks and if there is any fluid leaks, especially if it has been sitting.
there is the square end adjuster that sticks out of the backing plate, i was following the haynes manual that i have the other day. Thought i would ask on here as within a small amount of turning (1/4) the hub would not turn at all by hand, so backed it off a tiny amount and then would turn very freely. I think i will take the drum off and check the condition of everything like you suggested, cheers
