1.anyone works for nissan in chch
2.who has a 510 with factory twin su carbs.i need some measurements n pictures of carb linkages.
cheers
mohit
two question...
- kartboy
- aka: Hayden
Re: two question...
Scott Luxon works for Cockram Nissan here in Chch in the parts Dept. What are you after as my nephew also works there in service department. Can't remember what scott's user name is, you maybe able to find him under my friends list on face book.
- Tony_Whenua
Re: two question...
I think its birdflu isn't it?kartboy wrote:Scott Luxon works for Cockram Nissan here in Chch in the parts Dept. What are you after as my nephew also works there in service department. Can't remember what scott's user name is, you maybe able to find him under my friends list on face book.
- Area Reps
- aka: shane
Re: two question...
i have two rods one is 600mm long and the other 637 long one is sss and one is standard ......i will try hunt out a bracket for you to look at ........i found part numbers for brackets
upto 07 71 18310-22002 sss bracket
from 08 71 18310-u0800 sss bracket
- kartboy
- aka: Hayden
Re: two question...
Yip that's itTony_Whenua wrote:I think its birdflu isn't it?kartboy wrote:Scott Luxon works for Cockram Nissan here in Chch in the parts Dept. What are you after as my nephew also works there in service department. Can't remember what scott's user name is, you maybe able to find him under my friends list on face book.
Re: two question...
Thanks guys.
shane text me when you find the bracket pliz.
cheers
cheers
