Having a go at rebuilding the head and puting in new valves, into the lil push rodda, can someone comfirm valve clearance as being 1/100th inch (0.25mm) hot.
also if you have any points I should note to reduce the WT... factor
cheers
j15 head rebuild
j15 head rebuild
Re: j15 head rebuild
I have a 620 Haynes manual, but it's out on loan atm sorry.
I'll try to find out for you.
