Just finished front mounting a new 10" Davis Craig electric fan.
The kit came with a relay- is this necessary given that I am just wiring in a basic on/ off switch?
Also where would be the best place to grab a + wire to go through to the switch?
Dave
Wiring An Electric Fan
datsunboy
- aka: Dan
Standard switches aren't designed to run the switching current of fans or headlights etc hence the need for relays.
You've got the relay so wire it in.
Re: Wiring An Electric Fan
I trigger my fans from the Ignition on circuit , i borrowed a a signal wire from the ignition coil to get a +12v signal for the relay.
I would recommend fitting a thermo switch to your radiator. Fit a relay, run 12v + to the trigger side from the coil, and run the - side of the relay trigger off the thermo switch.
Thanks Guys.
Bart, I will in due course fit a thermo switch but in the meantime bearing in mind that we are talking about a race car I want to just run an on/off switch so I can manually control the fan.
With a switch in the dashboard where would be the easiest place to tap into to get a power feed- ignition switch?
Dave
Dave
Use the relay and take the trigger from the stereo,
- gman
- aka: gman
Ha that's what my race cars are missing a stereo.2 doors wrote:Use the relay and take the trigger from the stereo,
