Re: 2 doors 1200 2door sedan / engine now in
Great work Wal, it's almost a complete car now!
- aka: Braasy
Nice! Although you could have done this last week when I was there. I could have even helped
-- Nick/Braasy
-- Nick/Braasy
Cheers guys, just trying to get through stuff a bit at a time at the moment, Bart, I took it down to clutch systems and he skimmed it down, was bugger all and sorted the issues, he said the flywheel is sweet as to use, which is great.
Re: 2 doors 1200 2door sedan / glass is in
Ha, This is the issue with long standing projects.2 doors wrote:Had a bit of a headache as I somehow managed to spread all the hardware for the brake conversion to all corners of the garage, managed to get it all together and assembled in the end.
Did you end up having a play with the Aseries?
I had a look back through your thread but might have missed it. Only asking as you were tlaking about it last time we caught up?
Saw my first A series in the 1200 hole in a long time the other day without a super charger grafted on the side.
Seeing that and then looking at yours you forget just how low and backward they sit in the bay.
Good choice IMO going back original
torqued wrote:Ha, This is the issue with long standing projects.2 doors wrote:Had a bit of a headache as I somehow managed to spread all the hardware for the brake conversion to all corners of the garage, managed to get it all together and assembled in the end.
This one sits a bit lower than most, I notched out the cross member and lowered the sump, plenty of room around it for sure. I bought Bart's old motor, just a case of substituting the supercharger for a turbo, and adding efi. Can't wait to start it up.
Another day another thing done, welded in the plate for the fuel pump.
- aka: Bede
Looking good Wal. Sorry for my ignorance but are you still going A series Turbo?
Had a quick look back through but there are a lot of pages.
Im sure slotting the A series into a space made for a CA was a reassuring feeling you have made the right choice!
Lol yes, there is a picture on the previous pagedattoboy wrote:Looking good Wal. Sorry for my ignorance but are you still going A series Turbo?
Small update, I finished up the fuel tank this week, hopeing to get it painted tomorrow, and bolted in, then I'll take it down the road and put it on the hoist,and put in the fuel lines.
