WTB: Ignition and key
Bluebird_U
Regular
Post by Bluebird_U »
Hi I'm after an ignition and key for a Datsun Cherry. Looking on line it seems that one from a B210, B310, 620, 720, N10 pulsar or Sunny from the late 70's to mid 80's might fit.
The one that I have (don't know if its original or not) has Off/Acc/On/Start, 5 plug connectors to the wiring harness (one screw holding it in) at the rear and the drum is 34mm diameter and about 87mm long. The clamp for the steering column is 34mm diameter as well, and between the drum and column is about 40mm in length.
I have attached picture for reference. Thanks for your time.
R3spct
Datsun Dreamer
Re: WTB: Ignition and key
Post by R3spct »
http://www.ebay.com/itm/261959581263?it ... 23&vxp=mtr" onclick="window.open(this.href);return false;
Ive just ordered this for my coupe, complete lock set.
Did you by the one from the auction last weekend?
tlssunny
aka: jesse
Post by tlssunny »
I can check a b310 this weekend if you like? the plug on the back of them doesn't have a screw holding it in though
DATY12
Regular
aka: Kev
Post by DATY12 »
I have brand new ones for B210 1200 utes, I will need to check the measurements for you to see if its the same
Datsuns I've owned
Datsun Sunny x 4
Datsun 1200 Sedan
Datsun 1200 Roadstar Ute
-Current
Datsun C20 Vanette
Bluebird_U
Regular
R3spct, Yeah I went for a general look and got carried away - now just got to fix all the little things that are missing. Those locks look sweet, but at the moment I'm trying to get it going on a budget.
tlssuny - that would be great thanks, the screw holds the plug to the casing, but if all else is the same it should be good.
DATTY12 - thanks for that. I'm hoping that the legendary datsun parts bin works on this one.
DATY12
Regular
aka: Kev
Post by DATY12 »
I have checked the dimensions but they seem slightly different to yours sorry.
Barrel length from front of Barrel to the plug is 90mm
Bracket diameter for shaft is 40mm
Barrel to shaft bracket is 115mm
Ignition plug configuration is 3 x horizontal pins at the top and 2 x horizontal pins underneath on LHS.
Plug is held on by 1 screw.
Not sure if you can make this work or not?
Datsuns I've owned
Datsun Sunny x 4
Datsun 1200 Sedan
-Current
Datsun C20 Vanette
Bluebird_U
Regular
Thanks for that DATY12. Looks like it will stick too far out of the column surround and the steering is too large. If there nothing out there closer I might just have to get an ignition then drill out the pins holding the tumblers and swap them over.
taiparacer
Datsun Dreamer
Post by taiparacer »
have a couple of b310 that look the same
