WTD: z20e info
all your DIY needs
nzbidzel
WTD: z20e info
Post by nzbidzel »
z20e engine mounts compared to L series mount,differences any advice welcome
possible z20e forsale that could make into the 620 insteed of a L20b
Revolver
aka: Jack
Re: WTD: z20e info
Post by Revolver »
WILL fit your gearbox. Z20 (any 4 cylinder Z for that matter) will be in the wrong position as its meant go on an angle compared to the L motor; upright ! However mounts may be interchangeable ,I don't recall.? Either way you require the box, mounts, & motor . drive shaft should fit up.
gman
aka: gman
Re: WTD: z20e info
Post by gman »
I have a l20e and gearbox's if you are after one and it has the two peace manifold.
