ts cup replica b310 coupe
Re: ts cup replica b310 coupe
You won't regret buying the shrinker stretcher, good move getting one of each, so you don't need to muck around changing dies etc.
- woodies72coupe
Looking good Bud. Keep up the good work!
- tlssunny
- aka: jesse
nah wont be racing it I don't think.gman wrote:Just a half cage do you intend to race it?
- tlssunny
- aka: jesse
was only 300ish so really happy and arrived a couple days before xmas so I thought fuck it merry xmas jesse hahah2 doors wrote:You won't regret buying the shrinker stretcher, good move getting one of each, so you don't need to muck around changing dies etc.
- tlssunny
- aka: jesse
ok so just a wee update.
carbs already to go just need to machine 2 circlip grooves in the main pivot shaft and paint a couple of things black up it all works good and has plenty of space and movement through the full range
the drivers inner gaurd has a couple of spots i have bogged so just need to sand and then they will be ready
the front panel is basically ready to be welded in
the passenger side inner gaurd is tacked in atm but i need to go through and check all the measurements and make sure its straight etc before i fully weld it in
the normal just spot on the inner gaurds in engine bay i have finished the drivers side one and half way through the passenger side one
off to my engineer this week so should have more stuff done in a week or two
- tlssunny
- aka: jesse
and another update, i knew i did more shit than that
and i brought a 910 bluebird whooooop whoop
- tlssunny
- aka: jesse
sr20. I will start a build thread sometime
where have I seen that car before?
