torqued
aka: Adam
Post by torqued »
Can you turn the links so they bolt from the inside
Datto_610
aka: Greg
Post by Datto_610 »
I did try that but don't think it'll work. Got another set of universal links just got to cut them down to suit
Datto_610
aka: Greg
Post by Datto_610 »
The new uinversal sway bar links have been cut down and should clear the strut once installed. Ran and clipped the window washer lines in and got a brand new bonnet stay clip too. ImageImage
I had been putting it off for a while now but today I got right into getting the exhaust manifold off which is a prick of a job I really don't want to do again soon! Check manifold for straightness with my ruler and seems pretty straight so don't think I'll need it to get machined. Took a close look at the gaskets and you can see they've blown out a bit will fit my multi layer steel ones in soon! Im not sure if this is a silly question or not but seeing as these gaskets are meant to be the "bees knees" would I still need to put like rtv or maniseal on as well? I was told I didn't need to with the other composite gaskets and they leaked...ImageImageImage
DJZ
Post by DJZ »
Definitely no maniseal before the turbo. If the flanges are clean and flat you shouldn't need anything else.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
Datto_610
aka: Greg
Post by Datto_610 »
Sweet just finished googling it and that was also the general consensus on the interweb, same with spraying with copper gasket cement.
broke
Datsun Addict
aka: John
Post by broke »
I guess I'm the odd one out - I like that Permatex Ultra Copper super high temp RTV. I used it on the Laurel manifold gaskets and it worked great - only a thin smear mind you.
85_Z31
Datsun Master
Post by 85_Z31 »
the Multi layer gaskets actually seal by crushing the raised lip. If the surfaces are clean and straight then you should have no problems. I never once had any sucess with those composite gaskets
the VG30et is actually not running any gasket at all ( on Barts advice ) only the thinnest smear of RTV.
Clean and flat is going to make more difference than anything else.
tlssunny
aka: jesse
Post by tlssunny »
multi layered I wouldnt put any sealer on but those shit compostite ones I would runs a thin smear of high temp rtv etc
broke
Datsun Addict
aka: John
Post by broke »
Part of the reason for using it was to fill up the small scratches/pitting on the head etc from where it had been eroded slightly from having leaking manifolds due to broken studs.
Datto_610
aka: Greg
Post by Datto_610 »
Sweet will fit manifold back on soon!
