A Series Valve Gear
- gman
- aka: gman
Re: A Series Valve Gear
Valve springs more often than not brake from the valve gear not being set up properly ie rocker angel wrong spring rate to high to low. With all the A series I have dune money is best spent on alloy push rods 6mm valve stems titanium retainers or alloy if you have to. Then you can run a pretty aggressive cam and lift the spring rate by only a little from standard. If you want to get to 9 or 10 this is what I do.
Whereabouts did you source those bits from?
Dave
Dave
- gman
- aka: gman
I make my own retainers and buy the springs individually to match the valve stem length.If you are in CH CH go see Paul at Kennelly cams he will have what you need for a street car and good advice just be shore what you wont out off the car before you go.b110sss wrote:Whereabouts did you source those bits from?
Dave
- Regular
They are great quality, don't get me wrong. As a whole the Japanese spend big money for the name and quality/craftsmanship of parts which therefore pushes the ultimate function down the list. This boils down to expensive parts that aren't as well engineered as they should be.b110sss wrote:Hi Rob,
Thanks for that. Re the aftermarket Jap springs- that's a big call given Tomei and Kameari have such good names. Have you had bad experiences with them or do you feel they are simply overpriced for what they are relative to the local equivalent?
Dave
