Does anyone out there, have one of those Kangaroo windsceen washer bags, with a motor that works?
thanks!
Datsun 1200 coupe restoration parts wanted
Re: Datsun 1200 coupe restoration parts wanted
I have a pair of spare armrests but they have some cracks in the vinyl
Ive got a couple of brake masters, but no idea on condition. Might have some door arm rests, but once again no idea on condition.
Pretty sure i got my new master cylinder from BNT was pretty cheap too from memory!?
thanks, I have managed to find a couple of arm rests in my boxes of spares, this weekend.
I'l give BNT a call about the brake cylinder
thanks for the replies too
Im slowly restoring mine too, but i got it partially restored and fully stripped, so will be fun when its finally time to start putting it together. Are you doing work yourself?
I managed to find some arm rests spare at home.
But send me a private message if there is a brake master cylinder out there which is in ok condition.
My one is seized up.
I have stripped the car down, it is off to get the rust repaired and the car repainted by someone.
Then I will do as much of the reassembly as I can, but someone else will do the motor, gearbox etc
It's been off the road for 18 years and been in the same family since 1972
pretty sure I still have the box at home for my master cyl so can get you a BNT part number if needed?
All good, I managed to get one. thanks anyway
Hi
I'm after a few parts that I'm not able to find online.
Has anyone out there have a factory horn for a 1200.
Also one of the black plastic speaker grills
and a set of rubbers for the front quarter light windows
thanks!
thanks!
