2 doors
Post by 2 doors »
Try the earth on the drivers side , could be stealing the earth from the other side.
Was an idication of a fuse fault back i the day 180Bs were shockers for it. Fuse looks ok bug was dry jointed.
At least 2 relays. Datsun wiring is abit backwards with the headlights us switch I g earth and positives to get different beams. You are welcome to come have a look at the conversion on the 1600 and we can nut out what you need to do.
Datto_610
aka: Greg
Post by Datto_610 »
Yeah sounds good Vaughan!
85_Z31
Datsun Master
Post by 85_Z31 »
DJZ wrote:Relays are a good idea depending on how the car is set up originally, James and I have both done it, it's a bit of a pain to do but worked really well for me. Looks like a grounding issue possibly?
Mines got a relay each for high and low beam, with the Narva H4's it makes it easy to wire this way because they are a 3 pin bulb with common earth and +12 hi and +12 Lo.
It is a huge hassle but well worth getting it bang on. Mine ended up being a completely independent system , and from there i only took a signal from the stalk wiring. Because the stalk usually switches full current the brass pins get all cooked and burned. My car had a similar deal with one headlight working and one being really dim. Same as yours passenger side all funky.
I took my relay signal from the working side and the logic was that its no longer switching any load so it should last forever.
torqued
aka: Adam
Post by torqued »
Have you tried turning it off and on again?
Datto_610
aka: Greg
Post by Datto_610 »
torqued wrote:Have you tried turning it off and on again?
Yes.... many times and still don't work...
Datto_610
aka: Greg
Post by Datto_610 »
I'm using H4 for the hi/lo and H1 for the high beam. Yeah I've got no idea what I'm looking at really the relay on there only has 4 pins so a bit confused as to how to wire up 2 relays. It's probably simple to some of you haha.
What are you up to Wednesday?
Datto_610
aka: Greg
Post by Datto_610 »
After work? Currently no plans
What time is after work. Need to avoid family tea time.
7:30 would sut
