L28 blow through tubo.
- gman
- aka: gman
Re: L28 blow through tubo.
The main differences are in getting them to seal under boost and in getting the carbs to equal the boost fast enough and the way OER and HKS have dune it the carbs get up to boost presser before the runners.All the gasket faces have a raised ring around them to stop the gaskets from being pushed out under boost o rings on every thing fuel level and exsalrator pump all adjusts from out side at the top so you don't have to rip them apart to make fine adjustments . Floats are solid so they don't crush and the fuel float bowl and needle bowl have there own presser equalizing source .
- mitey1200
- Datsun Dreamer
Aw good to know. I bought some turbo gasket kits and dellorto top hats off eBay and seem to be holding up. Only 9psi at the moment but no dramas yet.
What boost are you planning on running?
- gman
- aka: gman
Well my son is going to race this one so it will go out on 10psi then 16psi if we have to.
- gman
- aka: gman
I got time to do weld the wastgate flange on today came up alright
Holy crap, that's beutifull .
One word, wow!
- gman
- aka: gman
Turbo and wastgate all back together.
- gman
- aka: gman
Bolted up turbo and wastgate along with plenum to make shore the clearances are all good . Just a 20mm spacer between the manifold and tubo needed.
Thats awesome
