Do you have to offset the engine to fit it all in?
Looks good Gman. Can see the design features there in the plenum Very interesting.
L28 blow through tubo.
Re: L28 blow through tubo.
- gman
- aka: gman
It looks like I will have to modify the inner gard a little to fit turbo and maybe remove or modify strut brace bar that goes from mid firewall to strut tower don't tell the scrutineers Vaughan
If you need to modify the inner guard , let me know and I'll give you a hand.
- gman
- aka: gman
Thanks man that very kind of you but I am saving you for things I cant do
Wow, that's cool!
- gman
- aka: gman
Well that went better than I expected motor and turbo went in with no modification to the guard at all just had to remove one bar for the plenum. no make the engine mounts.
man you dont stuff around aye.
Looking good Gman. I am picking there is a cover still to add to the plenum?
- gman
- aka: gman
yes there is a cover plate and and the two entry pipes for the turbo plus the recycling valve. Can't but them on till I fire it up and balance the carbs bring on next Saturday.
- 240znz
- aka: James
Yes, you don't stuff about Gman. I could do with a smidgen of your motivation.
