Datto_610
aka: Greg
Post by Datto_610 »
After having to break into my garage after work today. I can confirm that both big shims on each diff are 8mm thick
torqued
aka: Adam
Post by torqued »
Are they on the same side?
Datto_610
aka: Greg
Post by Datto_610 »
Yes they are. Same side but one has a small shim on the left side and the other has small shim on the right side of the big shim
Datto_610
aka: Greg
Post by Datto_610 »
Took her into work today and got one of the guys to do a few things for me (I would've done these myself but I'm in the office and wanted it done before the weekend which is when I get to use the workshop) so door locks and boot lock lubed no more feeling like the key is gonna snap! Checked out why my clutch pedal felt notchy which would seem the thread on the pushrod is damaged so need to whip that out and inspect, also looks like clutch slave cylinder is leaking... best thing was fitting the LD28 oil pressure sender which actually looks like it could be reading somewhat accurate! The one I did fit never read much on the gauge and then stopped working. Turned out it shat itself as something was rattling around inside it.... which sucks as it wasn't cheap...
Have a boost tap and gauge to fit soon too!!Image
Oil pressure looks good Greg, Do you have a light too? LD28 sender has both
Datto_610
aka: Greg
Post by Datto_610 »
No light set up yet but I do intend on hooking one up this sender has 2 terminals on it
I didn't have a factory light, and didn't want to cut into the dash or anything so just hooked up to the Brake warning light,
Datto_610
aka: Greg
Post by Datto_610 »
That's not a bad idea!
Datto_610
aka: Greg
Post by Datto_610 »
I've been getting a few things off Aliexpress recently and a few weeks ago I found some sun visor clips quite cheap so thought it could be worth a go, so ordered 2 sets (just incase they broke like all the 2nd hand ones I've tried) only got round to fitting them today and they worked perfectly! They are dark grey but I might paint them black which might look a bit better but stoked they worked out alright for how cheap they were!
I've also fitted a new boost gauge I got a while back too. It's not hooked up as it started raining while I was sitting in the car messing round with the sun visor clips.
DJZ
Post by DJZ »
That's a good find Greg, I guess they didn't have black ones? Mine are loose on the metal clip.
When are we going to see the CA maxing out that boost gauge?
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
